rockhillmanor wrote:
Great idea and great job installing it....but the reason they don't do that is the moisture.
In time the water will corrode the fixture wire connections and I'm afraid you will be having problems with the connections. 12 volt is 12 volt and I'd also be afraid of a shock situation. Just saying.
I just added one of the thousands of different types of cheap battery operated stick ups. They corrode and I throw it out and get a new one.
Good points....
The lights are waterproof automotive lights designed for outdoors, so corrosion and moisture issues should be minimal. If there is that much moisture above the skylight, I have bigger issues.
Has far as shock... The lines are fused with a maximum of 20amps.... Not not much to worry about there.
