gkainz's avatar
gkainz
Fastening a coat rack to a wall - no studs
I stuck a coat rack to the wall with velcro that was rated for what I estimated 3 coats would weigh, but I guess I underestimated, since it fell off the wall (velcro halves separated but each side stayed stuck to its respective surfaces). So, what kind of fastener have you used successfully through the wallboard?
  • mobeewan wrote:
    Are there any studs in the wall? Interior or exterior wall? I made a coat rack from a piece of oak I bought at Lowe's. Made it about 2 feet long to span 2 studs I found with an electric stud finder. Added 6 coat hooks. Used it to hang coats, pants, shirts & plastic grocery bags with potato chips, Doritos, Cheetos and other dry snack foods instead of filling up the cabinets with them. I even hung a mesh bag with oranges on it.
    . Best answer
    I have done this method many times. Chevman
  • 2112's avatar
    2112
    Explorer II
    I use #8 X 1" plastic expanding wall anchors.
  • We have Command Hooks on each side of the bed. I put them there the day we brought the camper home from the dealer (going on 5 years now). Hooks still there and are used all the time for hanging clothing.
  • I use an over the door hanger that I bought at Walmart. These are found in the bathroom department and are meant to hold bathrobes, toiletries, etc. You could easily hang three coats on it.
  • Are there any studs in the wall? Interior or exterior wall? I made a coat rack from a piece of oak I bought at Lowe's. Made it about 2 feet long to span 2 studs I found with an electric stud finder. Added 6 coat hooks. Used it to hang coats, pants, shirts & plastic grocery bags with potato chips, Doritos, Cheetos and other dry snack foods instead of filling up the cabinets with them. I even hung a mesh bag with oranges on it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Feb 20, 2024
