Wishbone51
Mar 31, 2016Explorer
TakingThe5th wrote:
I would not store the water hose below the stinky slinky but would rather see it above or ahead of the sewer hose. Venting the fence posts sounds like a good idea. I sanitize my water hoses and keep them capped when stored so that minimizes any problems.
Yes.. I plan on having them side by side, with maybe 6" between. Maybe I should put this one near the front of the trailer.
DutchmenSport wrote:
If you connect both ends of your water hose together, you won't have any cross contamination, any worse than laying the hose on the ground and a bird flies over head. The inside of the hose stays clean.
I do the same with my regular white hose, but to fit in the fence post, I wanted to get one of those coiled spring hoses. Won't be able to put the ends together in the tube, which is why I thought of the cap idea. CW sells a male and female cap set for $3.99
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
