Gdetrailer
Mar 28, 2018Explorer III
goducks10 wrote:
Fiberglass would crack as soon as you stepped on it. The 3/8" ply on the roof is soft and flexes. Seems very labor intensive especially making the curve look nice on the roof edge to side wall.
The OP is only planning two layers of fiberglass, so yeah, I would have to agree with goducks10..
Two layers simply will not be enough, it will take considerably more layers of build up to prevent cracking and breaking and that is without even standing on it..
One would want to consider going with a bulk resin gun and chopper gun to make that size of a job get done in a reasonable amount of time and cost..
Spray a layer of resin then layer of chopped fiberglass, work in with roller then repeat the process multiple times..
Fiberglass panels for a roofing application does not really work well.
I tried FRP panels, that worked for about 4 yrs, then started getting rips and tears from the extreme temp changes that happen on a roof.
Fiberglass has a pretty high expansion/contraction ratio and eventually that weakened the FRP to the point of cracking and ripping.
I faced the problem of finding another type of roofing..
Several RV dealers that I contacted mentioned a product called Peel & Seal.. The dealers did not want to order standard RV rolled roofing..
It is a sticky rubber backed material with a thin layer of aluminum foil on the top.
HERE
This is the second year on this material and so far has fixed my leaking issues..
You roll it out, use a roller to press it down and you overlap any seams.. It IS extremely sticky and you only get ONE chance to lay it down (picking it back up is not an option without destroying it)..
You WILL want a helper to help and do the install on a over cast day otherwise the shiny foil will burn your retinas..
Alternately, if that method does not appeal, then just order standard RV rolled roofing..
If I was going to ever face redoing my roof again, it WILL be a one piece sheet of heavy aluminum.. Lasts much longer than an rubber or soft roofing..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
