theoldwizard1
Mar 29, 2018Explorer II
Thanks for all of the feedback. I guess I did not think how much the 3/8" plywood flexes between roof trusses (16" O.C. or 24" O.C.). Doing more than 2 layers would be cost prohibitive.
This product looks very promising !
We need an annual report ! I would say if it lasts 10+ years, it is a winner !
"Heavy" aluminum ? While I do think aluminum with as few seams as possible is probably the best solution, material cost and installation would be very challenging !
Do you recall what type of aluminum it was (60xx or 52xx or ????)
Gdetrailer wrote:
Several RV dealers that I contacted mentioned a product called Peel & Seal.. The dealers did not want to order standard RV rolled roofing..
It is a sticky rubber backed material with a thin layer of aluminum foil on the top.
Gdetrailer wrote:
This is the second year on this material and so far has fixed my leaking issues...
Gdetrailer wrote:
If I was going to ever face redoing my roof again, it WILL be a one piece sheet of heavy aluminum. Lasts much longer than an rubber or soft roofing.
free radical wrote:
I covered my TC plywood roof with aluminum sheet 0.025 gage (25 mil/22 gauge ?). Used very expensive Evercoat tube epoxy @ 70$ a piece, to glue all edges down. To save money, I also used exterior carpet adhesive in the middle of these panels. Still dam expensive but it should last forever.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
