SDcampowneroper
Jan 01, 2017Explorer
theoldwizard1 wrote:ventless fueled heaters not only produce water which will condense on cold surfaces, but also use up the oxygen in your small space.
First, understand that any ventless propane heater will put a LOT of water vapor into the air. This may or may not be a problem.
For anything larger than a Big Buddy you need to make sure there is adequate clearance on all 4 side. Also check the consumption rate. You may have to refill one of your tanks while you are there.
Propane in pure value is c3h8, natural gas ch4., so when burned in an appropriate atmosphere they produce h2o , co2. In an oxygen lessened atmosphere, it produces h2o & co ( carbon monoxide) Be careful. be educated.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
