rhagfo
Jan 05, 2017Explorer III
:h
Artic Fox are well insulated, far better than our 2005 Copper Canyon. We are currently staying comfortable in our 32' rig using our Cheap Heat system on the 5,000 watt setting. This equates to 17,060 btu, so if you have a 30,000 or 35,000 btu furnace that should do fine down to about zero. Currently we are seeing temps down to 27 to 28 degrees over night.
Keep in mind that the furnace is the only way the underbelly gets heat to keep pipes from freezing.
I am one of the never a catalytic gas heater inside my rig!
I found that the install of the Cheap Heat system also improved the air flow over the gas heat exchanger so it works much better.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
