valhalla360
Feb 16, 2015Navigator
If you have a heavy duty alternator and you put in larger wires on the charging circuit it can work but as someone else suggested, you are drawing a lot of amps.
If you are only traveling a 2-3hrs, probably easier to just turn off the unit and turn it on when you arrive. As long as the door stays shut it should stay cold.
That said, I think you are worried about nothing. Sure there could be a strange set of circumstances that set it off but very unlikely. The bulk of RV's go down the road with the fridge set to propane and running.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
