oldtrojan66's avatar
oldtrojan66
inverter hook-up
This is for all you dry-campers with inverters. I have installed a kinda large one (3500 watts) in the next compartment over from my batteries. I used a (I think) 300 amp fuse and a bayonet type switch with 02 welding cable from batteries to inverter. Now the inverter has a double 120 volt receptacle, so I have an extension cord run up under the sink slide area. This is a pretty jury-rigged set up, but I don't know how I would hook up the inverter outlet to the 5er breaker panel and not overload the inverter. (I know, I would probably burn down the forest if I used 3500 watts at once, but I thought if big is good, bigger is better!) Anyone have a set-up similar to this and hooked up the inverter to the panel?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
