BurbMan
Feb 16, 2015Explorer III
eHoefler wrote:
The propane line is SCH 40 steel black pipe, very unlikely for it to fail from a blowout or any other impact. If it was a problem, the DOT and the NHTSA would stop the manufacture of propane equipped units.
^^^THIS^^^
The black pipe converts to the smaller 3/8" soft copper lines going to the appliances, but those connections should be out of harm's way. If all you have is black pipe by the tires then you are OK. IF you see the soft copper tubing by the tires then agreed that will get destroyed by a blowout.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
