time2roll
Mar 14, 2015Nomad
safrog wrote:You need about 400 watt inverter and I think you will be fine with a prechilled fridge. Probably need to plug in or run a generator to charge the battery at the destination.
Has anyone installed an inverter in an fifth wheel or trailer to run the 12v/Propane Refrigerator while moving. On my model the propane line from the tank to the unit is exposed in the event of a tire blowout and to dangerous to keep the tanks open when moving. I am thinking of installing an inverter to run the refer while moving. I think my truck wiring to the trailer has one wire to charge the battery in the unit but don't know if it will be enough to charge the battery (yes only one) to keep the inverter going. Anyone has experience in this area?
I have run mine on the inverter on a four hour drive but I have solar and a large battery. My Dometic fridge pulls 28 amps from the battery through the inverter when the cooling unit is cycled on. I had to do this because my propane failed to light and we were leaving right then. Fixed the igniter after arrival.
If you are not comfortable with propane then add the inverter without worry.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
