dockmasterdave's avatar
Apr 09, 2016
Figuring out an axle
OK, Not camping related, but I still want your opinions.
I have a 4x8 flatbed trailer that was homemade.
The seller told me it was made from the drop axle out of an old pick up.
I need to replace the lug studs with longer ones to make a wheel spacer work safely, or replace the whole hub.
Of course the studs are thoroughly rusted in place.
Catch is, I have no idea what truck the axle would have come out of.
I am hoping one of you will recognize it.
Here is some info I have:
It seems to be a 5 x 5.5" spacing.
It uses a timkin 1216 bearing for the outer.
I can't get a number off the inner, but I suspect a timkin,if I remember correctly I think I was looking at 1201.
Seems like it would be pre 1970 or so with front drum brakes.
I'm not sure how I can find out where this axle came from, but right now the trailer is out of commission.
I'll gladly accept any ideas you might have, and will try to get any dimensions that might help.
Thanks for any help you can offer.
  • Ivylog wrote:
    For less than .......$200 you can have a 3500 lb Dexter axle that you can bolt to your springs. Granted you will probably have to cut it to shorten the axle and reverse the camber as you are going to bolt it under the springs.
    This is what I would do ^^^^
    Rather than jack around with an old rusted experiment.
  • Ivylog's avatar
    Ivylog
    Explorer III
  • Thanks Donn:
    I sprayed WD 40 on the studs of one hub, threaded the nut on, till flush with the stud, beat it with a 10lb sledgehammer.
    It laughed at me.
    I went to a trusted mechanic to see about heating them with a torch. He recommended getting a new hub.
    He said I would have a lot of trouble finding new studs of this type.
    I was also wondering about having them pressed out.
    I knew I could get some good advice here.
  • Early Dodge or International front axle, around the 60's early 70's.
  • Studs come in only a couple of sizes. Take a hammer and pound one out. Take it to NAPA and ask them for the same diameter but longer. Don't forget new nuts too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
