way2roll
Jun 04, 2024Trailblazer
The rate at which your FW tanks fills is completely contingent on the flow rate of the source filling it and the rate at which your tank can accept water. Do you have good flow at the source, does it have a pressure regulator on it? Mine has an overflow, I watch the sensor to tell me when it's full, but on most sensors, full isn't really full.
As Nick mentioned, emptying your tanks is complete when stuff stops flowing out. A few factors here as well, like the design of your tanks, if you are level etc. And the sensors often are inaccurate. I find that a black and grey flush helps keep the sensors clean and in working order.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
