papper's avatar
papper
filling fresh water with city water hook up
For those of you like me that do not have tne luxury to be able to fill your fresh water tank direct with city water hookup here's what to do.Go to your fresh water pump and install a tee in the pump suction line and one to the outlet line. Now run a line between these two tee's with a shut offvalve. To fill the tank with city water hook up just open this newly install bypass valve.Make sure the pump is shut off.
To explain this. The pump suction line is hook up to the fresh water tank and the pump outlet line is hook up to city water so with this bypass open city water will fill the tank.I always open the tank lid in case the vent line would be plug. After the tank is full don't forget to shut off the valve
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
