aboeck3's avatar
aboeck3
Fresh water fill
Need some help, I’m getting frustrated. When I am hooked up to city water I have no water pressure - not low - no water. When I am using water from tank and using the water pump I have good pressure. I have changed the water inlet valve twice. Last one is a good brass valve. It worked good for about 10 hours, then no pressure. I don’t know what else to do. It is like somewhere things are getting plugged up. Does pumped water go through the whole coach filter? Could it be clogged? Any thoughts will be appreciated. Thanks in advance.
2017 Winnebago Journey 42E
