mockturtle
Sep 11, 2014Explorer II
Bumpyroad wrote:I put a hose clamp on mine. I also extended the clear plastic hose with another foot or so of slightly narrower tubing.
I would recommend that if you use one of those commercial units with the foot long plastic tube and shut off valve that you silicone seal the tube to the fitting before you lose it down into the tank.
bumpy
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
