sch911
Sep 12, 2014Explorer
Blacklane wrote:
Not when you're filling the tank with a 5/8" hose. You must reduce the flow to less than a third, since the area of a 3/8" diameter hose is about 1/3 the area of a 5/8" hose. It's actually far less than that, since the air not flowing out of the vent is flowing against the water you're trying to put in.sch911 wrote:Blacklane wrote:
Apparently not. I have a 1" hose into the tank and a 3/8" vent connected to a lockable fill port on the outside of my camper.
Sounds like you have a blockage in the vent hose. The 3/8 hose is more than enough to pass the air out of the tank if functioning properly.
Not going to argue with you other than to point out the density of the air is much less that the water. Hence the smaller hose requirement for the vent. I'm done now...
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
