Blacklane
Sep 14, 2014Explorer
Blacklane wrote:
Original poster here.
For everyone who thinks I might have an insect or something in my vent opening, I don't see how, since it's covered with a screen (the small hole on the bottom right).
It's also obvious that I don't have a kink in either the fill line nor vent line. The biggest problem is that I have a long horizontal hose to my fresh water tank (the green/white hose).
A regular hose-end will only fit into the opening an inch or so, and when you turn on the water, it just splashes back unless you turn the volume down really low.
My solution is to insert a long fill hose (with no connector) into the fill port all the way to the bottom of the tank. Then I can turn on the water to maximum and the tank fills from the bottom up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
