babock
Feb 12, 2020Explorer
naturist wrote:A 100W panel can put out 7A when it's aimed perfectly and using an MPPT controller. With 5 hours equivalent sun that's 35AH. With a PWM controller, it's more like 5 or 6A. If the panel is flat mounted knock off around 30%.
HThat battery can be well supplied by 100 watts of solar assuming full sunshine and that you use no more than the 40 amp hours the battery can supply without causing premature damage.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
