Mmaxed
Feb 21, 2020Explorer II
jdc1 wrote:allen8106 wrote:
I'm curious about how you added solar to the rig in 1 1/2 hours. Mine took days. You don't mention the battery monitor, inverter, shunt or any fusing.
I already knew where I was mounting everything. Climbed up. Bolted down the panel. Ran the wire through the hole in the roof (into a box made for rv rooftops)to a fused 20A controller. Ran the wire to battery along the water line to an jacknife shutoff in the battery storage are. Then put the last fuse (30A) in place just before the battery bank. I did it all before noon, so there were no beer breaks.....and the wife was at a quilt retreat, so she couldn't bother me.
It seems to be working great. With no obstructions, it should be able keep my batteries (3-80 amp/hr) charged fairly well when boon docking.
Are you sure it's enough to run the water pump?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
