- 2oldmanExplorer II
ramyankee wrote:
50 watts. A 50a panel would be a monster.
it is a Furrion and think it is only 50 amp. - ramyankeeExplorerDebating solar. The one panel that Open Range sells, think it is a Furrion and think it is only 50 amp. Is the plug on say an Open Range a generic plug so most any panel will connect? For an example the panels from Harbor Freight.
Thank you... - 2oldmanExplorer II100 watts won't be enough either, unless your power usage is very low. Carry extra water in the tow vehicle and pump it in.
- ppineExplorer IIIHow long are you going out there for? Water weighs around 8.3 pounds per gallon. Train your crew to use less water as an alternative.
- LwiddisNavigatorWill 25 to 30 amps on a good day be adequate?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
