a64armt's avatar
a64armt
Fireplace removal and repurposing space
Has anyone removed the Factory installed RV fireplace and repurposed the space? I don’t see is using it much. I was considering removing it and building an insert that will house and obscure cat litter box, lined with waterproof paneling, hinged front door, small pet doors for entry.
Thoughts?
  • We also winter in Florida in out mh. We don't have room for an electric fireplace, so I put a toe-kick heater in. Wired to the same circuit as the AC. It has it's own t-stat.
    Works a lot better than a portable, always in the way, heater. And works a LOT better.
  • We use our fireplace almost daily when wintering in Florida. To remove the morning chill, and during cold spells. Saves on propane. We have pulled ours out to change the light bulbs, so removing it is easy. Remove the trim, unscrew all the screws, unplug and it comes right out. The space isn’t that wide, however. I would think repurposing it would be fairly simple.
  • I never realized how much we use our fireplace until we had one. Our fireplace is pretty shallow as in maybe 8 inches without much space behind it. So for us it wouldn't be worth removing it even if we wanted to.
    Dan
  • We bought our Cougar without the fireplace. I added 3 shelves in the cabinet and turned it into a canned food pantry. It works great and really holds a large number of cans.
  • ScottG wrote:
    We use the heck out of ours. You might try it before you rip it out.
    Also, the compartment for ours was only about 10" deep (most fireplaces aren't any deeper than that). If you haven't already removed it anc checked, it may not be all that big back there.
    The depth might be the deciding factor. We have dual heat pumps, but admit the fireplace might be nice if we do any cold weather camping
  • We use ours spring and fall when we have hookups sure saves on the propane !!! Just a fancy electric heater.
  • We use the heck out of ours. You might try it before you rip it out.
  • I had one in our previous MH. We got more use out of it than any other appliance bar none. RVs don't hold the heat so when the sun goes down and the temps go down, we turned on the fireplace to keep it comfortable. Liked the ambiance too.
    If you want to remove it, there's nothing to it. Take out the screws on the sides and pull it out. You'll find a cord plugged into an outlet behind it. Plug the cord and pick up the fireplace. At least that's how it was on my unit.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Sep 13, 2025
