time2roll
Sep 23, 2016Nomad
#2 is probably overkill for 35 amps. Are you even getting 14.4 volts out of the converter? Usually that is the issue with WFCO but some of the older ones seemed to work better.
Otherwise I would just max out the existing connectors and stick with the fuses and distribution that you have.
If you are not getting 14.4 volts I recommend replacing the converter with IOTA or Progressive Dynamics.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
