time2roll
Sep 26, 2016Nomad
#2 wire is fine although you may have trouble getting it into the terminals. Then you need to clip some strands or use a step down connection.
If you replace the entire charging loop with #4 and have two batteries you may as well get PD4655 or PD9260. Only reason to stay with 35 amp would be for using a small 1000 watt generator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
