nayther
Sep 02, 2018Explorer
fixed my brakes
had really crappy brakes and have not been able to get it in for warranty. Wasn't sure if it was truck or trailer until I towed my son's trailer last month and all was good. Pulled break away and ...
theoldwizard1 wrote:
Do a good 3 wire splice/tap is not easy to do. Here is my method, which is also what I do for a 4 wire splice/tap.
- Start with butt splice that is one size LARGER than is required
- Strip all wires
- Twist together 2 from different circuits (in the picture above, the back and on blue)
- Insert and crimp this into one end of the butt splice
- Use a piece of scrap wire (or the fourth wire)and do the same for the remaining wires. Trim the scrap off and close to the splice as possible.
- Heat shrink (either a separate piece or use shrinkable insulated butt splices) are a MUST !
