Hank_MI
Jun 27, 2017Explorer
You said you blew out the line to the fresh water tank then water came pouring out. That means there was **** plugging up the line. Most likely the **** got into the pump which has a filter screen on the input side. Usually, with pump off, you can twist the input cap off. You can then remove the filter screen inside that may be plugged up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
