My fridge fan is louder and whinier inside the trailer than outside. There are 4 fans, fridge is in a slide, so side vented. Anybody done a mod to reduce the sound?
For fridges mounted in slides, I have wondered if using a 10~14" electric radiator fan mounted on one (or both) of the outside covers would work well. You could even use a speed controller so it doesn't have to turn faster than needed to reduce noise. They're cheap and flow a ton of air.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
