TURNKEY's avatar
TURNKEY
Fridge Vent Fan Questions
Two questions, and I would appreciate the wisdom of the crowd:
1-I want to add vent fans to my small 5ver's fridge 'chimney' to improve cooling. I intend to use 2-3 computer fans. I assume it would be better to mount them at the very top of the chimney,(just under the bug screen that caps the chimney below the top roof cap) so as to 'pull' the air up, rather than on the inside of the bottom vent or below the cooling unit and try to "push the air up.
This is based on my belief that the heat generated by the fridge will naturally rise and will build up from the top down in the chimney. Just like an attic fan will cool your house better than trying to push air into your basement with a fan.
2-I don't want the fans to run if it isn't necessary. (We are off grid 95% via solar and I HATE all generators. Even mine.) Therefore I intend on installing a thermo switch to control at what temperature the fans will kick off and on. What temperature should it be rated? And where should it be placed?Norcold 6.3 foot reefer.
Thanks for your help.
  • Not Scot!
    I used some foam board and attached to wall with Liquid Nails. Thickness will be of what you need.
  • Scott...can you tell us what you did to decrease the space between the wall and the coils. To the OP... a simple inline toggle switch will work if you don't want to go with the thermo switch. You could do both (I like to be able to shut things off completely)
  • I believe ScottG is asking about clearance around the cooling unit.
    There is some specifications for how much distance between the cooling coils and the exterior wall of the rig. Most specifications are for less then an inch.
    By closing up this area, more air goes through the cooling unit improving the efficientcy.
  • It also helps to fine tune the install of the fridge to the guidelines in the installation manual. Rarely if ever do manufacturers adhere to clearances and chiminey shape that are specified.
    I just spent an entire day doing that very chore.
