Lynnmor
Nov 30, 2017Explorer II
When I replaced my cable operated valves, I ran small diameter tubing to the same place shown in the video. I used an old valve to test the silicone lubricant and it worked for a very short time, then it swelled the shaft seal making the valve tight and useless. Then I tried the same test on another valve using motor oil and that worked.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
