Edd505
Jun 27, 2017Explorer
You will need at least a 3000 watt, the least expensive (quite) inverter today is the Champion 3100I or it's replacement the 3400I. Harbor Freight has come out with a 2000I but you'll need two & a parallel kit to run the A/C. The HF has not been out long enough to tell how they will hold up. I have had good luck with their compressors etc.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
