MrWizard
Jul 17, 2017Moderator
Not suitable in an enclosed compartment
It will overheat
Built in generators have specially designed fresh air intake and hot air out
Stick your hand under a running Onan and feel the warm air from the engine blower
To use a portable while driving, a rear mount carrier mount might work and give you the ! Open space and air flow, if air turbulence is not to bad
It will overheat
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 10, 2026
