wbharris357
Mar 30, 2017Explorer
Might be an ignorant question but where would the transfer switch be located? There is a gen switch in the trailer that has a start indicator.
I'll be using the same cable for either the shore line hookup or the generators so I couldn't have them both hooked up at the same time.
It was a standard 3 wire (ground, neutral, power). 30amp.
I have run it on the twin paralleled eu2000i Hondas through the shore line power hook up.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
