bgum's avatar
bgum
Generator shelf fabrication
planning to fab a shelf on my trailer tongue to carry a generator. The generator weights a little less than 50 pounds. It will be located between the propane bottles and the camper shell over the battery. I plan to use 1 inch square tube made from aluminum or steel. Question is what material would you use and why? Difference in weight is not a factor. It will stand about 10-12 inches above battery.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,396 PostsLatest Activity: Nov 18, 2025
