PSW
Jul 11, 2014Explorer
Thanks for the responses. I am going to go with the 3M tape after researching it. I think I will also use Dicor around the edges to seal it off good so no water works down to the tape.
I put a voltmeter on the Renogy bendable panel and it was right on specs when in full sun. Hard to believe a hundred watts and four pounds!
PSW
PSW
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
