MrWizard
Apr 30, 2014Moderator
Your meter can't read the real startup load, it's not fast enough
If you look on the compressor, very likely you will see an LRA of about 50 amps
Lock Rotor Amps, this is the true high pressure restart value
It's unlikely you will see much drop off the startup load on your meter
What you will notice is less lugging of the generator when the compressor starts
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
