Howdy to all. Our CG shuts off the water during winter which I understand. We use the CG showers. But every now and then the wife wants to soak in the tub in our tt. I can get pails of water if I wa...
If you can get buckets of water can't you just fill your holding tanks with that water and use the on board water heaters to get hot water where ever and when ever you need it? Is the coach winterized and not capable of utilizing the plumbing that was designed in. There are a number of way of getting water into your coach so we would need to know how you are setup be it gravity feed or pressurized city water only.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
