TheKunkelsExplorerMar 19, 2017Heat waterHowdy to all. Our CG shuts off the water during winter which I understand. We use the CG showers. But every now and then the wife wants to soak in the tub in our tt. I can get pails of water if I wa...Show More
westendExplorerMar 20, 2017Harbor Freight sells this dandy little 12V transfer pump. You could use a dark colored bladder or barrel and Mr Sun will heat the water.I do like those water trough heaters, though. Just make sure that if you use it in the tub to remove it before inserting Wife.
About DIY MaintenanceRV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
Related ContentWater pump?Why no hot water?Water PumpAnother heated water hose questionALDE heating and water heating system. Comments welcome.
