Howdy to all. Our CG shuts off the water during winter which I understand. We use the CG showers. But every now and then the wife wants to soak in the tub in our tt. I can get pails of water if I wa...
Our seasonal campground also has no water, but there are plenty of ice fishermen/snowmobilers/ATV'ers that come up in winter.
They fill these coolers up with hot water and use them if they need hot water.
We heat water on the stove in our park model if required and put it in an insulated container in the same fashion. I think a couple of the 5 gallon containers might work for you - then again getting the water heated in the first place is the tough part.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
