RobWNY
Aug 19, 2020Explorer
I can't offer you any help in how to fix your problem but I can tell you that before you add rollers or whatever solution you try, you need to check the top of the slide to make sure it can be raised the needed amount without hitting or causing the seal to bind which would then create a leak issue on top of the problem you already have.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
