CA_Traveler
Aug 19, 2020Explorer III
My bedroom bed slide has 3 small adjustable rollers that might work for you, about 3/4" diameter. One is on one end between the slide and raised floor for the engine. The other side roller is much larger. The other 2 support the bed box which is a larger storage area under the foot area. All 3 are screwed to the floor. When I removed and repaired the bed box I didn't take a picture. With enough research related to Monaco hopefully you can find more information online.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
