- Dutch_12078Explorer II
- ajridingExplorer III have seen thousands of other styles.
I am looking for this exact one. There have to be more still out there... - ndrorderExplorerTry searching 'surface mount 12v outlet'. While none exactly like you have, there are many options available.
- RoyBExplorer IILooked all around and could not find what you are wanting.
There is a bunch of DC Charging stations out there however that install behind a wall panel...
This is one from ETRAILER
Google Image
I use two of these 12VDC charge stations from AMAZON Blue Sea items...
google image
Have two of these installed in my POPUP trailer one of each end... Allows you to plug in several 12VDC items to charge up... Sockets and USB connections etc...
If you do get one of these with the 12VDC METER on them be sure to get one that has an ON-OFF Switch on it. The 12VDC Monitors get very bright at night and you will want a way to turn it off haha...
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Feb 14, 2025
