Gjac
Dec 21, 2018Explorer III
If your genset is under your bed like mine you probably have space between the top of your genset cover and the under side of your bed. I store blankets, pillows etc in this space and around the sides of the cover. The only reason I run the genset at night is to use the AC. The AC makes more noise than the genset now. I do feel a slight vibration but no noise. A layer of lead sheeting bonded to the inside of the genset compartment would be another way to reduce noise inside the bed room. 6 ins of blankets etc on top and 12 ins on the side of pillows will insulate sound more than 1/2- 1 in of acoustical foam. At least that is my experience.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
