rockerbox
Dec 26, 2018Explorer
I think I'll first try to install a new floor on the storage compartment floor including absorbent material plus a layer of plywood, That will be the easiest to do. It should stiffen the layer just above the generator and should reduce some of the noise propagation from below. Since the generator is supported from this floor structure, I suspect most of the vibration noise is transmitted from that surface. Thanks to DrewE and all for the suggestions.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
