firetruckin
Feb 07, 2016Explorer
Thanks for the reply. Some of the problem I'm having is the difference in wire colors. As I showed earlier the larger wires (red and blue) go to the furnace. I did figure out that his green wire is for the Hi fan. He doesn't have a grey wire on his old thermostat. He has a black one but I'm not sure if that is the same. Also I'm not sure if I need to use the new thermostat connection labeled "R". My Hunter did not have that.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
