Old-Biscuit
Feb 07, 2016Explorer III
Thick RED..........RH/RC (with jumper)
Thick BLUE.........W
YELLOW.............Y
Thin RED.......not used...wire nut/tape off
BLACK (Low A/C Fan Speed)
GREEN (High A/C Fan Speed)
Connect both to 'G' for High Fan only
Connect BLACK to 'G' for Low Fan only
Or install a mini toggle switch so you can switch between Hi/Lo
Center terminal to 'G'
BLACK to a terminal
Green to other terminal
BLACK to a terminal
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
