firetruckin's avatar
firetruckin
Help with digital thermostat install
I am trying to help my father out by installing a digital thermostat into his Safari motorhome. I have successfully installed the Hunter in my own RV but can not get his wiring figured out. The first issue is that I was unable to find the Hunter thermostat available anywhere so I purchased the Supco 43054. It appears to be the same as the Hunter except for one additional wire hook up labeled "R" (separate from "Rh/B and Rc/O"). He has a brand new Suburban furnace and the factory dometic A/C unit. I'll see if I can get some pictures posted to see if someone can help me figure out which wires go where. Thanks in advance for any help someone can provide.
  • Here is a thread that helped me a great deal when I recently changed air conditioners and had to put in a new thermostat in my trailer. Note especially the post by Old-Biscuit about half way down the page.
    Hope it helps you.:)
    Barney
  • Here is the new thermostat. The colors of his old thermostat wires don't match colors in all of the posts I've searched for months.
  • Here is the old thermostat. The red and blue wires are from the furnace.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
