LaneW
Jan 20, 2023Explorer
ewarnerusa wrote:LaneW wrote:
... I was told by some that the 206 ah SOK will not produce 1000 amps continuous power, needed for the inverter, and that two 100s will. I have had some tell me this is true, other say not. I dont know for sure and would love to have a definitive answer!
maybe misplaced a zero? The 100AH Li batteries that I have looked at have a battery monitoring system that limits them to 100 A max continuous output. 2 in parallel would give you 200 A. 200A x 10V (reduced from 12V for inversion efficiency losses) = 2000 watts on the AC side. So should pair fine with your 2000 watt rated inverter plan and hopefully do OK for starting up your microwave.
Yes, definitely added a zero accidentally! Renogy has a 200 ah batt that is rated for 200 a continuous, but it wont find my small space. I would rather use the SOK 206 ah but will prob have to go with two of their 100 ah
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
