DrewE
Oct 25, 2016Explorer III
It sure does sound as though the furnace isn't getting power or the thermostat isn't properly calling for heat. Either one should be fairly straightforward to check with a multimeter. I'm assuming you otherwise have 12V power available in the RV--that is, the lights work, etc.; if not, then that's your more basic problem.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
