braindead0
Sep 02, 2016Explorer
Wet bolts and shocks on the suspension if you don't already have that. Flip the axle and swap out entry step with a longer one if needed. After flipping you can probably go to a slightly wider tire, at the least get tires that have a load rating high enough that you can safely air them down a bit (20 PSI vs. 60 PSI can make a huge difference).
All of these mods can be done pretty easily if you're handy and have tools, if not a shop should be able to do it. I think an "E-Z Flex Heavy Duty Rubber Suspension System by Dexter Axle - 5-5/8" Equalizers" or something similar will cover the tandem axle equalization AND wet bolts.
All that being said, people have been hauling trailers off road for a long time. Other than the axle flip, these upgrades will just allow you to do it a bit faster..
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 30, 2026
