Frenchy33's avatar
Frenchy33
Upgrading Handle
I'm wanting to upgrade from the small factory handle on my entry way to a large D-shaped folding handle. How do you know where it's safe to install something that you need to be tied to the framework of a wall? I would assume (but uncertain) that the structural support for the existing handle runs vertical floor to ceiling. But what if I wanted to install something that I have no point of reference to a possible stud? I have a Coleman Lantern, which has aluminum exterior, so I doubt a traditional stud finder would work.
  • If you already have the small handle, it's screwed into the frame. just measure from the edge of the door the the center of the "screw covers" on the handle. When you decide where you want the new mounting hardware use those measurements and drill your new holes.
    That's what I did for both of the handles I added to our trailer 3 years ago and have no problems. Just shoot sealant in the holes, add some to the screw threads and install. It worked for me.
  • Almot's avatar
    Almot
    Explorer III
    mike-s wrote:
    Seon wrote:
    Would using a "stud" finder work?
    Is that like a chick magnet?
    Stud finder is a legitimate term in this industry.
    It will work, on the wall inside. Never tried it on corrugated aluminum outside. With wooden studs you need an ultrasound stud finder, not $5 gizmo relying on a magnet. I used Prosensor 710 by Franklin Sensors, to find studs in different places in trailer. Home Depot have a similar model by Ryobi.
  • my jayco did NOT have framing around the door, the door frame had to be taken out and a stud put in to support the D handle
  • I did exactly what you want to do. There should be framing around the door opening. Look on the inside, push and/or tap on the paneling. Look for staples in the paneling. All of this will help indicate where the framing is located.
  • Sometimes a morning frost will outline the support structure on the exterior siding. As it gets warmer you might start looking for this and if it happens it will answer your question.
  • I've never run in to a rig that didn't have framing for a handle mounted directly next to the door. Many times, you can leave the existing handle and mount the new one above and below the original.
  • 1- look at other campers like yours and see where their d handles are bolted to.
    2- open door and look inside the frame where the deadbolt goes into and that will show you how far wide the alum or wood studs are.
  • Entry door area is going to be 'framed out'
    Close inspection from inside you may be able to determine exact location of vertical supports
    And sometimes you just have to go with thru the wall bolts with a backer board....especially with something like a entry grab bar
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
